Ir para o conteúdo principal
Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: passo 1, imagem 1 %32 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: passo 1, imagem 2 %32 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: passo 1, imagem 3 %32
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  2. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 2, imagem 1 %32
    • Use screwdriver to remove screws.
  3. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 3, imagem 1 %32
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  4. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 4, imagem 1 %32
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  5. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: passo 5, imagem 1 %32
    • The front sliding lens cover.
  6. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 6, imagem 2 %32
    • Remove four screws using Phillips located on the inside of the front cover.
  7. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 7, imagem 2 %32
    • Remove front sliding lens cover.
  8. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 8, imagem 2 %32
    • The front sliding lens cover is now removed and may be repair or replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Stephannie Allen
Membro desde: 03/11/13
255 Reputação
Autoria de 10 guias
Equipe
Clemson, Team 13-1, Benson Spring 2013 Membro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 20
Duração total: 1,213
