Ir para o conteúdo principal
Sony Cyber-shot DSC-T9 CCD Module Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T9 CCD Module Replacement, Battery: passo 1, imagem 1 %32
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 2, imagem 1 %32
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: passo 3, imagem 2 %32 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: passo 3, imagem 3 %32
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 4, imagem 1 %32
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 5, imagem 1 %32
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 6, imagem 1 %32
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 CCD Module Replacement, CCD Module: passo 7, imagem 1 %32
    • This is the CCD module.
  8. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 8, imagem 1 %32
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  9. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 9, imagem 1 %32
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  10. Sony Cyber-shot DSC-T9 CCD Module Replacement: passo 10, imagem 1 %32
    • The CCD module is now removed from the camera.
Conclusão
3 outras pessoas executaram este guia.
Stephannie Allen
Membro desde: 03/11/13
255 Reputação
Autoria de 10 guias
Equipe
Clemson, Team 13-1, Benson Spring 2013 Membro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 871
