Ir para o conteúdo principal
Sony Cyber-shot DSC-T9 Back Cover Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T9 Back Cover Replacement, Battery: passo 1, imagem 1 %32
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 2, imagem 1 %32
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: passo 3, imagem 2 %32 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: passo 3, imagem 3 %32
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 4, imagem 1 %32
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 5, imagem 1 %32
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 6, imagem 1 %32
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Back Cover Replacement, Back Cover: passo 7, imagem 1 %32
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 8, imagem 1 %32
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 9, imagem 2 %32 Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 9, imagem 3 %32
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 10, imagem 2 %32 Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 10, imagem 3 %32
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 11, imagem 1 %32
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Back Cover Replacement: passo 12, imagem 1 %32
    • The back cover is now removed from the internal hardware.
Conclusão
Stephannie Allen
Membro desde: 03/11/13
255 Reputação
Autoria de 10 guias
Equipe
Clemson, Team 13-1, Benson Spring 2013 Membro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 531
