Ir para o conteúdo principal
Sony Cyber-shot DSC-T9 AV Port Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T9 AV Port Replacement, Battery: passo 1, imagem 1 %32
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 2, imagem 1 %32
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 AV Port Replacement, Back Cover: passo 3, imagem 1 %32
    • This is the camera without the front cover.
  4. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 4, imagem 1 %32
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-T9 AV Port Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-T9 AV Port Replacement: passo 5, imagem 3 %32
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-T9 AV Port Replacement: passo 6, imagem 2 %32 Sony Cyber-shot DSC-T9 AV Port Replacement: passo 6, imagem 3 %32
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 7, imagem 1 %32
    • Remove the back cover.
  8. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 8, imagem 1 %32
    • The back cover is now removed from the internal hardware.
  9. Sony Cyber-shot DSC-T9 AV Port Replacement, CCD Module: passo 9, imagem 1 %32
    • This is the CCD module.
  10. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 10, imagem 1 %32
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  11. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 11, imagem 1 %32
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  12. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 12, imagem 1 %32
    • The CCD module is now removed from the camera.
  13. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: passo 13, imagem 1 %32 Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: passo 13, imagem 2 %32
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  14. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 14, imagem 1 %32
    • Remove metal screw plate.
  15. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 15, imagem 1 %32
    • Use pry stick to pop off ribbon.
  16. Sony Cyber-shot DSC-T9 AV Port Replacement: passo 16, imagem 1 %32
    • Remove AV port from camera.
Conclusão
Stephannie Allen
Membro desde: 03/11/13
255 Reputação
Autoria de 10 guias
Equipe
Clemson, Team 13-1, Benson Spring 2013 Membro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 13
Duração total: 600
