Ir para o conteúdo principal
Sony Cyber-shot DSC-T1 LCD screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T1 LCD screen Replacement, Battery: passo 1, imagem 1 %32
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 2, imagem 1 %32
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: passo 3, imagem 2 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: passo 3, imagem 3 %32
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 4, imagem 1 %32
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 5, imagem 1 %32
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 6, imagem 1 %32
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 7, imagem 2 %32
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 8, imagem 2 %32
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
  9. Sony Cyber-shot DSC-T1 LCD screen Replacement, LCD screen: passo 9, imagem 1 %32
    • Use the plastic opening tool to flip the top clip that holds the ribbon to the motherboard unit.
  10. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 10, imagem 2 %32
    • Flip the motherboard unit up to expose the metal plate beneath it.
    • Remove the four 3mm screws shown using the 00 screwdriver.
  11. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 11, imagem 1 %32
    • Lift and remove the metal plate covering the LCD screen from the camera.
  12. Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 12, imagem 2 %32 Sony Cyber-shot DSC-T1 LCD screen Replacement: passo 12, imagem 3 %32
    • Flip the LCD over to the other side of the camera.
    • Peel the tape connecting the LCD to the camera.
    • Remove LCD screen
Conclusão
Paul Elrich
Membro desde: 04/12/12
45 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-35, Maness Spring 2012 Membro de Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 56
Ao todo: 4,241
