Ir para o conteúdo principal
Sony Cyber-shot DSC-T1 Flash Module Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 2, imagem 1 %32
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 2 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 3 %32
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 4, imagem 2 %32
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: passo 5, imagem 1 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: passo 5, imagem 2 %32
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 6, imagem 1 %32
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: passo 7, imagem 1 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: passo 7, imagem 2 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: passo 7, imagem 3 %32
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 8, imagem 2 %32
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
Conclusão
iDeleted
Membro desde: 07/07/10
2.101 Reputação
Autoria de 39 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 2,492
