Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the cover on the bottom of the camera.
Slide the cover towards the back of the camera.
Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0 screwdriver.
Pull the two halves of the camera apart.
Place the two halves down with the insides facing you.
Find the two clips holding the motherboard to the black lens box.
Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it up. (If difficult, your fingernail can also be used)
After releasing the clips, pull out the black lens box.
Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
With the tweezers remove the black tape to detach the chip from the lens box.
Grab the chip with your thumbs and carefully pull it off.
3 outras pessoas executaram este guia.
