Ir para o conteúdo principal
Sony Cyber-shot DSC-P9 Top Button Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P9 Top Button Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 2, imagem 1 %32
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-P9 Top Button Replacement: passo 3, imagem 2 %32
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: passo 4, imagem 1 %32 Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: passo 4, imagem 2 %32
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-P9 Top Button Replacement: passo 5, imagem 2 %32
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-P9 Top Button Replacement: passo 6, imagem 2 %32
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 7, imagem 1 %32
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Top Button Replacement, Top Button: passo 8, imagem 1 %32
    • Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
  9. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 9, imagem 1 %32
    • Pull off the pieces of casing located on either side of the top button of the camera.
    • Both of the two pieces should slide off very easily. Do not force them off.
  10. Sony Cyber-shot DSC-P9 Top Button Replacement: passo 10, imagem 1 %32
    • Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
Conclusão
Andrew Forster
Membro desde: 04/16/12
12 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-25, Amido Spring 2012 Membro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 692
