Ir para o conteúdo principal
Sony Cyber-shot DSC-P9 LCD Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: passo 2, imagem 1 %32
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-P9 LCD Replacement: passo 3, imagem 2 %32
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: passo 4, imagem 1 %32
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-P9 LCD Replacement: passo 5, imagem 2 %32
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: passo 6, imagem 1 %32
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-P9 LCD Replacement: passo 7, imagem 2 %32
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: passo 8, imagem 1 %32
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: passo 9, imagem 1 %32
    • The LCD is now separated from the camera.
Conclusão
Jenna Crawford
Membro desde: 04/09/12
50 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-25, Amido Spring 2012 Membro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 1,072
