Ir para o conteúdo principal
Sony Cyber-shot DSC-P52 Viewfinder Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P52 Viewfinder Replacement, Outer Case: passo 1, imagem 1 %32
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 2, imagem 1 %32
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 3, imagem 1 %32
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 4, imagem 1 %32
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 5, imagem 1 %32
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 6, imagem 1 %32
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 7, imagem 1 %32
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Viewfinder Replacement, Lens: passo 8, imagem 1 %32
    • Remove the two additional screws on the back of the lens.
  9. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 9, imagem 1 %32
    • Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
  10. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 10, imagem 1 %32
    • Remove the motherboard and the flash from the rest of the hardware.
  11. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 11, imagem 1 %32
    • Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
  12. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 12, imagem 1 %32
    • Remove the three screws shown to separate the lens from the viewfinder.
  13. Sony Cyber-shot DSC-P52 Viewfinder Replacement: passo 13, imagem 1 %32
    • Purchase a new viewfinder.
    • Repeat the previous steps in reverse order to rebuild.
Conclusão
Kari Johnson
Membro desde: 01/10/11
127 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-43, Regan Winter 2011 Membro de Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,167
