Ir para o conteúdo principal
Sony Cyber-shot DSC-P52 Motherboard Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P52 Motherboard Replacement, Outer Case: passo 1, imagem 1 %32
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 2, imagem 1 %32
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 3, imagem 1 %32
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 4, imagem 1 %32
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 5, imagem 1 %32
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 6, imagem 1 %32
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 7, imagem 1 %32
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard Assembly: passo 8, imagem 1 %32
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  9. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the cable on the back side of the motherboard.
  10. Sony Cyber-shot DSC-P52 Motherboard Replacement: passo 10, imagem 1 %32
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
  11. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard: passo 11, imagem 1 %32
    • The motherboard is now free, and ready to be replaced by a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Trevor
Membro desde: 01/20/11
295 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-43, Regan Winter 2011 Membro de Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,116
