Ir para o conteúdo principal
Sony Cyber-shot DSC-P100 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P100 LCD Screen Replacement, Back Casing: passo 1, imagem 1 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement, Back Casing: passo 1, imagem 2 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement, Back Casing: passo 1, imagem 3 %32
    • Remove the four screws from the casing.
  2. Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 2, imagem 2 %32
    • Carefully pull the back casing away from the camera.
  3. Sony Cyber-shot DSC-P100 LCD Screen Replacement, LCD Screen: passo 3, imagem 1 %32
    • Using a pry tool, gently pry the top right corner of the LCD screen. Pry the screen until the four tabs release it from its current position.
  4. Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 4, imagem 2 %32
    • Push the metal tab on the right side of the screen until the plate underneath the LCD screen is released.
  5. Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 5, imagem 2 %32
    • Unfold the LCD screen and the plate underneath.
    • Now visible are the ribbon cables holding the screen and plate in place.
  6. Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 6, imagem 2 %32 Sony Cyber-shot DSC-P100 LCD Screen Replacement: passo 6, imagem 3 %32
    • Remove the LCD screen plate by gently pulling upward on the ribbon cable until the screen is removed from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Katie McCraw
Membro desde: 03/09/12
191 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-5, Benson Spring 2012 Membro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Membros
Autoria de 14 guias
2Comentários do guia
Hello!
Thank you for this tutorial.
I just disassembled a Sony DSC P1 (3Mega pixel).. And i would like to ask you if you knew if we may reuse the screen, or the sensor, or other components, in a different set up. Can we access the technical documentations of the inside components of sony's cameras? My intention would be for example to use the sensor with another lens and make another board ? Maybe im just too ambitious..
Thank you very much for your answer.
junkymilk - Responder
I have a question in regards to this camera. My wife has had one for years and then all of a sudden it started beeping and said something on the screen about the memory card that was inside. Does this mean the card with all the photos is bad? Maybe installing a new card would make this camera usable again? Thank you.
Ronald Mountin - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 2,228
