Ir para o conteúdo principal
Sony Cyber-shot DSC-P100 Front Casing Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P100 Front Casing Replacement, Front Casing: passo 1, imagem 1 %32 Sony Cyber-shot DSC-P100 Front Casing Replacement, Front Casing: passo 1, imagem 2 %32 Sony Cyber-shot DSC-P100 Front Casing Replacement, Front Casing: passo 1, imagem 3 %32
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Front Casing Replacement: passo 2, imagem 1 %32
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Front Casing Replacement: passo 3, imagem 1 %32
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Front Casing Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-P100 Front Casing Replacement: passo 4, imagem 2 %32
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
Conclusão
Katie McCraw
Membro desde: 03/09/12
191 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-5, Benson Spring 2012 Membro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Membros
Autoria de 14 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 14
Ao todo: 1,305
