Ir para o conteúdo principal
Sony Cyber-shot DSC-P100 Camera Lens Replacement
O que você precisa
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: passo 1, imagem 1 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: passo 1, imagem 2 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: passo 1, imagem 3 %32
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 2, imagem 1 %32
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 3, imagem 1 %32
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 4, imagem 2 %32
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: passo 5, imagem 1 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: passo 5, imagem 2 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: passo 5, imagem 3 %32
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 6, imagem 2 %32
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: passo 7, imagem 1 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: passo 7, imagem 2 %32
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 8, imagem 3 %32
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: passo 9, imagem 1 %32
    • The lens is now successfully removed from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Katie McCraw
Membro desde: 03/09/12
191 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-5, Benson Spring 2012 Membro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
Membros da 4
Autoria de 14 guias
Um comentário
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 2,578
