Introdução
This guide will show you the steps to remove and replace the lens of the camera
O que você precisa
Place the device so bottom of the camera is facing up .
Remove the five marked screws with a Phillips #000 screwdriver.
Insert the spudger where arrow marks to gently remove the lower panel.
Use the plastic opening tool with a prying motion to remove the side cover of the camera.
Remove the small screw under the multi/USB cover.
Use the plastic opening tool to remove the button board.
There are 3 more screws to remove!
do you mean 3 more or 3 screws to remove if so where are they? thanks
ColBunn -
Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
Es muss vor dem lösen des Flachbandkabels vom Display die Verriegelung der Anschlussbuchse über den kleinen Hebel (schwarz oder grau) entriegelt werden. Diesen vorsichtig von hinten in Richtung Flachbandkabel hochklappen aber Vorsichtig!
Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
Je n'arrive pas à rebrancher ce câble et la photo ne m'aide pas. Est-ce qu'il va sous la petite barrette de la carte mère, comme je pense mais je n'arrive pas à le glisser, ou dans le pli de l'autre câble plat qui arrive à cette barrette?
Si vous suivez encore ce fil....énorme merci d'avance.
Press on the lens with your finger.
Gently pull the lens container out of the camera.
8 outras pessoas executaram este guia.
5 comentários
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
