Ir para o conteúdo principal
Sony Cyber-shot DSC-HX90V Lens Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: passo 1, imagem 1 %32 Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: passo 1, imagem 2 %32
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
    • Insert the spudger where arrow marks to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 2, imagem 1 %32
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 3, imagem 1 %32
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 4, imagem 1 %32
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  5. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 5, imagem 1 %32
    • Remove the black M1.4 X 3.5 Phillips head screw.
  6. Sony Cyber-shot DSC-HX90V Lens Replacement, Side cover: passo 6, imagem 1 %32
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: passo 7, imagem 1 %32 Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: passo 7, imagem 2 %32
    • Remove the small screw under the multi/USB cover.
    • Use the plastic opening tool to remove the button board.
  8. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-HX90V Lens Replacement: passo 8, imagem 2 %32
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  9. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 9, imagem 1 %32
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
  10. Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: passo 10, imagem 1 %32 Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: passo 10, imagem 2 %32
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
  11. Sony Cyber-shot DSC-HX90V Lens Replacement: passo 11, imagem 1 %32
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
  12. Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: passo 12, imagem 1 %32 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: passo 12, imagem 2 %32 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: passo 12, imagem 3 %32
    • Press on the lens with your finger.
    • Gently pull the lens container out of the camera.
    • Make sure all ribbon wires are unplugged.
Conclusão
8 outras pessoas executaram este guia.
Marin Rusinov
Membro desde: 02/02/17
853 Reputação
Autoria de 5 guias
5 comentários
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Leon - Responder
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
Under multi cover
Dufour - Responder
First at step 7
Dufour -
At step 8 remove two 2mm screws both lower sides of LCD
Dufour - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 34
Últimos 30 dias: 133
Ao todo: 12,514
