Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place the device so bottom of the camera is facing up .
Remove the five marked screws with a Phillips #000 screwdriver.
Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
Remove the marked screw with a Phillips #000 screwdriver.
Use the plastic opening tool to remove the button board.
Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
Use the plastic opening tool with a prying motion to remove the side cover of the camera.
Orient the device so the lens is facing down.
Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
Remove the black M1.4 X 3.5 Phillips head screw .
Remove the ribbon cable connecting LCD display to camera sensor and battery housing gently.
19 comentários
The title says this is a lens replacement, but isn't it in fact an LCD replacement?
This is truly a terrible guide. There are numerous steps missing, steps in the wrong order and little or no description of where and how to apply any pressure to separate or remove parts. I’m glad I didn’t follow this guide as I quite likely would have ruined my camera, or at the very least caused more and quite possibly expensive-to-repair damage. I strongly urge ifixit staff to investigate this guide and remove it, or to at least strongly warn anyone who is contemplating following it.
Hallo David,
mit dieser Anleitung habe ich schon mehr als 20 Displays gewechselt und es ist mir noch nie etwas kaputt gegangen. Es fehlt auch nichts was man hätte noch schreiben können. Wenn Du Angst hast etwas kaputt zu machen lass die Finger davon.
Hier rumkritisieren ist schon ein bisschen unverschämt, diese Übersetzung schreibe ich in meiner Freizeit! Du kannst ja eine neue bessere Anleitung schreiben aber vermutlich bist Du jemand der die Finger von solche Reparaturen lassen soll. So eine Reparatur erfordert Sachverstand, wenn es Dir mit dieser Anleitung nicht gelingt, fehlt Dir dieser.
Gruß Detlef
Entschuldigung,
nach dieser Anleitung habe ich schon 20Displays gewechselt ohne das etwas kaputt gegangen ist.
Wenn man sich dieses nicht zutraut oder 2 linke Daumen hat, Finger weg!
Hello Detlef. Will you consider doing a video tutorial please?
