Ir para o conteúdo principal
Sony Cyber-shot DSC-HX90V Button Board Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: passo 1, imagem 1 %32 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: passo 1, imagem 2 %32 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: passo 1, imagem 3 %32
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 2, imagem 3 %32
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 3, imagem 3 %32
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
Conclusão
Marin Rusinov
Membro desde: 02/02/17
853 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 1,956
