Ir para o conteúdo principal
Sony Cyber-shot DSC-HX90V Battery Replacement
  1. Sony Cyber-shot DSC-HX90V Battery Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the camera is turned off prior to the removal of the battery.
    • Place the camera upside down with the top sitting on the flat surface.
    • Using your fingers, slide the door lock to the unlock position.
  2. Sony Cyber-shot DSC-HX90V Battery Replacement: passo 2, imagem 1 %32
    • Open the battery compartment door.
    • Remove the battery from the compartment by turning the camera upside down.
    • Insert the new battery into the compartment matching the positive battery lead to the positive terminal and the negative battery lead to the negative terminal on the camera.
Conclusão
Marin Rusinov
Membro desde: 02/02/17
853 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 2,315
