Ir para o conteúdo principal
Sony Cyber-shot DSC-HX300 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX300 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 2, imagem 1 %32
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 3, imagem 1 %32
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 LCD Screen Replacement, LCD Screen: passo 5, imagem 1 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down the camera, remove the battery, and unplug your device before you begin.
    • Use a Phillips head screwdriver to remove one 2 cm screw located on the inside portion of the LCD hinge.
  6. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 6, imagem 2 %32
    • While using a plastic opening tool, carefully remove the plastic housing that surrounds the hinge.
  7. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 7, imagem 2 %32
    • Using a small Phillips head screwdriver, remove the (2) 2 cm screws on the back of the LCD display, as indicated in the photo.
    • Turn the camera on its side to access the last remaining 2 cm Phillips head screw holding the LCD case together.
  8. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 8, imagem 1 %32
    • Remove the plastic cover from the back of the LCD display by simply sliding it up and off of the camera.
  9. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 9, imagem 2 %32
    • Using a plastic opening tool, carefully remove the plastic housing that surrounds the LCD display.
  10. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 10, imagem 2 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 10, imagem 3 %32
    • Once the plastic housing is separated, disconnect the ribbon wire located on the back of the LCD display. This can be achieved by pulling up lightly on the brown bar that locks the ribbon wire to the circuit board..
    • Disconnect the remaining two ribbon wires the same way. They are located on the right, rear side of the LCD frame.
  11. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 11, imagem 1 %32
    • Using a small Phillips head screwdriver, remove the last 2 cm screw that mounts the circuit board to the metal LCD display frame.
  12. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 12, imagem 2 %32
    • Once the circuit board is removed the replacement parts can be installed in the reverse order.
Conclusão
To reassemble your device, follow these instructions in reverse order. It is important to follow the steps in this order as it may not turn on properly if the user does not follow every step.
Elizabeth Surface
Membro desde: 08/26/15
1.453 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 4-6, Meier Fall 2015 Membro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Membros da 4
Autoria de 18 guias
2 comentários
my screen is working but in negative effect, any ideas??
wilmer - Responder
Comment réparer la carte circuit imprimé de l'écran? Il y'a un transistor qui reçoit 3.7v et qui laisse rien sortir
Abdoul Traore - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 29
Duração total: 4,118
