Ir para o conteúdo principal
Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 2, imagem 1 %32
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 3, imagem 1 %32
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 4, imagem 2 %32
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: passo 5, imagem 1 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: passo 5, imagem 2 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: passo 5, imagem 3 %32
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 7, imagem 1 %32
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 8, imagem 3 %32
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 9, imagem 2 %32
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
  10. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: passo 10, imagem 1 %32
    • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
  11. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 11, imagem 1 %32
    • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
  12. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 12, imagem 1 %32
    • Once the HDMI/USB Port is removed the replacement can be installed.
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth Surface
Membro desde: 08/26/15
1.453 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 4-6, Meier Fall 2015 Membro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 1,465
