Introdução
Repair for this component requires a screwdriver and plastic prying tools. When removing the lens block be wary of the capacitor.
O que você precisa
Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
Use a prying motion and a plastic opening tool to pry the side panel up.
Pull the panel down there are 2 clips in the midtle be carefull not to brake them
It is not clips but "hook" so to the mouvement should be at opposite direction on flash
I inserted an opening pick under the lower part of the panel (where it was loosest; at the left of the photo) and then inserted a jimmy along one side (at the top of the photo). Then I pushed the panel down from the top (at the right in the photo) and it popped off.
Orient the device so that the LCD is facing you ("back view").
Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
when screen cable is plug, you can test before reassemble the device.
Help this is an urgent need please !!! I am stuck at step 12 : lifting the black retaining clip up just pops it out like a pop corn (tried several times) and then nothing moves :-(
No need to unplug the LCD, to take the lens
Il est inutile de débrancher l’écran LCD pour retirer l’objectif
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of the device.
Service manual for reference: Click to go to the service manual.
Lift the lens block from the case.
Exactly with this very helpful description I have successfully changed my noisy lense system
thans a lot D. A. Waldvogel
11 outras pessoas executaram este guia.
7 comentários
Can you tell me how to open Sony hx20v lens..... I have problem in my Sony camera n I don't know how to fix the lens I try several times but I'm so worried about to break any part or wrong fix. Please show how to open lens (only lens) part.....please..sorryforbadenglish.
These guides are best suited if you are replacing parts. There's no 'repairing' the individual components. If you can find another broken camera of the same model (but with a good lens) then you could replace it.
can i follow the same instruction for SONY DSC HX 10V .as both looks identical . when i shake my camera sound comes as if some parts are loosen but when i switched on my camera and the lens comes out that sound goes off . should i care for it or not ?
I followed all the steps and I was able to fix a problem with the lens. Thanks a lot! ! ++
I have successfully changed with the help of your description my noisy lense system
thanks a lot
D. A. Waldvogel
Hi!
Thanks for this tutorial. My HX20V had a buzzing noise in the lens and i couldn't take photos or videos. I follow this instructions to disassemble the camera and another Youtube video to disassemble and clean de lens body (this was more tricky). Finally I assembled all the parts and guess what... the camera is 100% functional and the noise disappeared.
Many thanks!
