Ir para o conteúdo principal
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: passo 1, imagem 1 %32
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 2, imagem 3 %32
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 3, imagem 1 %32
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 4, imagem 1 %32
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 5, imagem 1 %32
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 6, imagem 2 %32 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 6, imagem 3 %32
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
Conclusão
Uma outra pessoa concluiu este guia.
DaQuawn
Membro desde: 03/05/15
254 Reputação
Autoria de 2 guias
Equipe
Um comentário
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 947
