Ir para o conteúdo principal
Sony Cyber-shot DSC-HX1 Lens Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 2, imagem 1 %32
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 3, imagem 2 %32
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: passo 4, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: passo 4, imagem 2 %32
    • Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
  5. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 5, imagem 1 %32
    • Unscrew the four #00 4.0 mm Phillips screws on the bottom of the camera.
  6. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 6, imagem 1 %32
    • Remove the two #00 4.0 mm Phillips screws shown on the side of the camera.
  7. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Unscrew the #00 4.0 mm Phillips screw on the top next to the view finder.
  8. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 8, imagem 1 %32
    • Pull open the plastic port covers on the side of the camera.
    • Remove the revealed #00 4.0 mm Phillips screw.
  9. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 9, imagem 2 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 9, imagem 3 %32
    • Lift the back LCD screen to reveal the back of the camera unit.
    • Unscrew the three #00 4.0 mm Phillips screws at the edge and center of the back camera unit.
  10. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 10, imagem 2 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 10, imagem 3 %32
    • Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
    • Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
    • Apply moderate force to the backside of the camera enclosure until the two pieces separate.
  11. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 11, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 11, imagem 2 %32
    • Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
    • Disconnect the eight ribbon cables from their ports on the motherboard.
  12. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 12, imagem 2 %32
    • Detach the metal bracket from the enclosure by removing the two #00 4.0 mm Phillips screws.
  13. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 13, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 13, imagem 2 %32
    • If you feel resistance from the board, double check all screws and cables have been removed to avoid damage.
    • Completely remove the motherboard by gently pulling the board away from the camera.
  14. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Lens Assembly: passo 14, imagem 1 %32
    • Unscrew the #00 6.0 mm Phillips screw on the left side of the lens.
  15. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 15, imagem 1 %32 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: passo 15, imagem 2 %32
    • The lens assembly contains exposed leads to capacitors. Be very careful to avoid contact or discharge capacitors before handling as touching the capacitors could lead to electric shock.
    • Gently slide the lens assembly out of the front camera housing and remove completely.
Conclusão
5 outras pessoas executaram este guia.
Brianna Greenlaw
Membro desde: 04/06/15
1.241 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-3, Forte Spring 2015 Membro de Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Membros
Autoria de 10 guias
2Comentários do guia
Hi!
Very good tutorial, thanks a lot.
I have a question : after reassembling the device, do you need to do some kind of adjustment or is it "simply plug-and-play"?
Best regards,
Marin
Marin Aymon - Responder
Muy bueno el tutorial felicitaciones, sin embargo faltaron tornillos por nombrar, saludos
Cesar Carrillo - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 69
Ao todo: 5,892
