Ir para o conteúdo principal
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: passo 2, imagem 1 %32
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: passo 3, imagem 1 %32
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: passo 4, imagem 1 %32
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: passo 5, imagem 2 %32
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: passo 6, imagem 1 %32
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
Conclusão
6 outras pessoas executaram este guia.
Brianna Greenlaw
Membro desde: 04/06/15
1.289 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-3, Forte Spring 2015 Membro de Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Membros
Autoria de 10 guias
5Comentários do guia
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - Responder
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - Responder
Screen LCDOnline booking
prince Choudhary - Responder
qual tela de lcd posso usar?
não achei
Thayane Laurencio - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 49
Ao todo: 3,903
