Ir para o conteúdo principal
Sony Cyber-shot DSC-HX1 Button Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 2, imagem 1 %32
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 3, imagem 2 %32
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: passo 4, imagem 1 %32
    • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
  5. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 5, imagem 2 %32
    • Lift the button housing from its position on top of the camera.
Conclusão
Brianna Greenlaw
Membro desde: 04/06/15
1.217 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-3, Forte Spring 2015 Membro de Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 947
