Ir para o conteúdo principal
Sony Cyber-shot DSC-HX1 Battery Replacement
  1. Sony Cyber-shot DSC-HX1 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Battery Replacement: passo 2, imagem 1 %32
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Battery Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-HX1 Battery Replacement: passo 3, imagem 2 %32
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
Conclusão
To reassemble your device, insert the new battery in the compartment, making sure that your battery has the correct orientation, then follow these instructions in reverse order.
Brianna Greenlaw
Membro desde: 04/06/15
1.241 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-3, Forte Spring 2015 Membro de Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 29
Ao todo: 1,365
