Ir para o conteúdo principal
Sony Cyber-shot DSC-H300 Batteries Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H300 Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Flip the camera over to look at the bottom side.
  2. Sony Cyber-shot DSC-H300 Batteries Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-H300 Batteries Replacement: passo 2, imagem 2 %32
    • Place thumb on battery cover and slide outward until it springs open.
    Battery opening will not spring open
    John Greenwood - Responder
    Same! What was your resolve?
    William Foltz -
  3. Sony Cyber-shot DSC-H300 Batteries Replacement: passo 3, imagem 1 %32
    • Remove the batteries.
    How do you charge the camera? I’ve tried and I can’t seem to figure it out
    Mona Said - Responder
Conclusão
3 outras pessoas executaram este guia.
Zachary Meyer
Membro desde: 02/14/18
479 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G6, Nance Spring 2018 Membro de USF Tampa, Team S1-G6, Nance Spring 2018
USFT-NANCE-S18S1G6
3 Membros
Autoria de 10 guias
7 comentários
I got the Sony Cyber-shot DSC-H300. I didn't see any battery charge pack in it, only the batteries.
Please I want to know if I'm required to charge the batteries or only replace them when they discharge
Nee Nath - Responder
This uses AA batteries. I’m sure you could use rechargeable batteries as well but I just replace them
Terri S. -
My battery door won't open. It was working until now. Any suggestions?
jer2911alexis - Responder
For any one with this issue it might mean you batteries might have leaked and you can check if there is any white colored residue at the unlock button if , as with my camera i saw some residue, after using something that will not leave marks to push it to unlock position and try to force it a bit to the side the cover, just enough to push something in the edge of cover and housing on the underside near edge of battery cover hinge , to push out the cover a bit more to the side so it slides out to open it and then lift up , just have to clean out the residue of leaked battery of everything in special metal battery contacts on the battery cover , i am trying to find out if there are any replacement parts to replace the metal battery contacts, as i haven`t seen anything yet here
shydar -
The camera door will no longer spring ooen. Any suggestions?
Does Sony make rechargeable battery packs for this camera?
Sue Smith - Responder
Maybe you guys are doing it the wrong way! I was trying to open it from the side. I finally opened it from the part next to the hole and it opened immediately. 😭😭
YourLocalGogi - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 55
Últimos 30 dias: 178
Ao todo: 10,974
