Ir para o conteúdo principal
Sony Cyber-shot DSC-H200 Tripod Port Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: passo 1, imagem 2 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: passo 1, imagem 3 %32
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 2, imagem 1 %32
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 3, imagem 1 %32
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 4, imagem 2 %32
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 5, imagem 1 %32
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 6, imagem 1 %32
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 7, imagem 2 %32
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 9, imagem 2 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 9, imagem 3 %32
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
  10. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Motherboard: passo 10, imagem 1 %32
    • Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
  11. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 11, imagem 1 %32
    • Disconnect all wires from the motherboard by using a soldering iron.
    • Users unfamiliar with a soldering iron should be extremely careful as the device can get very hot.
  12. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 12, imagem 1 %32
    • Gently lift the motherboard away from the camera body.
  13. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Tripod Port: passo 13, imagem 1 %32
    • Using a screwdriver, remove the four 4mm screws from the motherboard.
    • Then remove the single 4mm screw connecting the motherboard to the main body of the camera.
  14. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 14, imagem 1 %32
    • Lift the motherboard away from the camera body (the tripod port is exposed)
  15. Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 15, imagem 1 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 15, imagem 2 %32 Sony Cyber-shot DSC-H200 Tripod Port Replacement: passo 15, imagem 3 %32
    • Using tweezers, lift the tripod port up and away from the camera body
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 1,347
