Ir para o conteúdo principal
Sony Cyber-shot DSC-H200 SD Door Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: passo 1, imagem 2 %32
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 2, imagem 1 %32
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 3, imagem 1 %32
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-H200 SD Door Replacement: passo 4, imagem 2 %32
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-H200 SD Door Replacement: passo 5, imagem 2 %32
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 6, imagem 1 %32
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 7, imagem 1 %32
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-H200 SD Door Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 9, imagem 1 %32
    • Remove the door.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 1,694
