Ir para o conteúdo principal
Sony Cyber-shot DSC-H20 Lens Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 2 %32
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 2, imagem 1 %32
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 3, imagem 2 %32
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 4, imagem 3 %32
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 5, imagem 1 %32
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 6, imagem 2 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 6, imagem 3 %32
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 8, imagem 2 %32
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 9, imagem 2 %32
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 10, imagem 2 %32
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 11, imagem 1 %32
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Rachel Payne
Membro desde: 02/23/15
386 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Leahy Winter 2015 Membro de USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 39
Duração total: 2,674
