Ir para o conteúdo principal
Sony Cyber-shot DSC-H20 Front Cover Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: passo 1, imagem 2 %32
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 2, imagem 1 %32
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 3, imagem 2 %32
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 4, imagem 3 %32
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 5, imagem 2 %32
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 6, imagem 2 %32 Sony Cyber-shot DSC-H20 Front Cover Replacement: passo 6, imagem 3 %32
    • Pry the front cover of the camera off with the plastic opening tool.
Conclusão
3 outras pessoas executaram este guia.
Randal Ackett
Membro desde: 02/23/15
182 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Leahy Winter 2015 Membro de USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
Membros da 3
Autoria de 10 guias
Um comentário
I need a new battery port. It has a broken lid and doesn’t keep it closed. Anyone knows where can I get one?
rubens brakarz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 15
Duração total: 954
