Ir para o conteúdo principal
Sony Cyber-Shot DSC-W830 Button Board Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: passo 1, imagem 1 %32
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 2, imagem 1 %32
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 3, imagem 1 %32
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: passo 4, imagem 2 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: passo 4, imagem 3 %32
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 5, imagem 1 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 5, imagem 2 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 5, imagem 3 %32
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 6, imagem 1 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 6, imagem 2 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 6, imagem 3 %32
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: passo 7, imagem 1 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: passo 7, imagem 2 %32
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 8, imagem 1 %32 Sony Cyber-Shot DSC-W830 Button Board Replacement: passo 8, imagem 2 %32
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Conclusão
Uma outra pessoa concluiu este guia.
Addyson Salalila
Membro desde: 09/15/16
316 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-1, Blackwell Fall 2016 Membro de USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,724
