Introdução
This guide will help you to replace the top panel on the Sony Cyber Shot DSC-W170.
If the shutter button or the power button are not working properly, the solution is to replace the top panel unit. Be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
O que você precisa
Remove the first side panel to the left of the LCD.
Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
Lift up the black bar on the top flat ribbon cable with tweezers.
Gently pull the flat ribbon cable until it disconnects from the lens assembly.
