Ir para o conteúdo principal
Sony Cyber-Shot DSC-W170 Top Panel Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: passo 1, imagem 2 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: passo 1, imagem 3 %32
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 2, imagem 1 %32
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 3, imagem 1 %32
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: passo 4, imagem 2 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: passo 4, imagem 3 %32
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 5, imagem 1 %32
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: passo 6, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: passo 6, imagem 2 %32
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 7, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 7, imagem 2 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 7, imagem 3 %32
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 8, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 8, imagem 2 %32
    • Gently push the connector through the hole to separate the LCD from the metal casing.
  9. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: passo 9, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift up the black bar on the top flat ribbon cable with tweezers.
    • Gently pull the flat ribbon cable until it disconnects from the lens assembly.
    • Be gentle when dealing with the flat ribbon cable.
  10. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 10, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 10, imagem 2 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 10, imagem 3 %32
    • Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
  11. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 11, imagem 1 %32
    • Lift the two flat ribbon cables with tweezers.
  12. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 12, imagem 1 %32
    • Peel back the flash assembly on the back of the lens.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver.
  13. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 13, imagem 1 %32
    • Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
  14. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 14, imagem 1 %32 Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 14, imagem 2 %32
    • Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
  15. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 15, imagem 1 %32
    • Push out the lens assembly very gently.
  16. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 16, imagem 1 %32
    • Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
  17. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 17, imagem 1 %32
    • Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
  18. Sony Cyber-Shot DSC-W170 Top Panel Replacement: passo 18, imagem 1 %32
    • Pull the top panel off gently.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 54
