Ir para o conteúdo principal
Sony Cyber-Shot DSC-W170 LCD Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: passo 1, imagem 2 %32 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: passo 1, imagem 3 %32
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 2, imagem 1 %32
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 3, imagem 1 %32
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: passo 4, imagem 2 %32 Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: passo 4, imagem 3 %32
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 5, imagem 1 %32
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: passo 6, imagem 1 %32 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: passo 6, imagem 2 %32
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 7, imagem 1 %32 Sony Cyber-Shot DSC-W170 LCD Replacement: passo 7, imagem 2 %32 Sony Cyber-Shot DSC-W170 LCD Replacement: passo 7, imagem 3 %32
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 8, imagem 1 %32 Sony Cyber-Shot DSC-W170 LCD Replacement: passo 8, imagem 2 %32
    • Gently push the connector through the hole to separate the LCD from the metal casing.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 391
