Ir para o conteúdo principal
Sony Cyber-Shot DSC-W170 Front Panel Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-W170 Front Panel Replacement, LCD Panel Assembly: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-W170 Front Panel Replacement, LCD Panel Assembly: passo 1, imagem 2 %32 Sony Cyber-Shot DSC-W170 Front Panel Replacement, LCD Panel Assembly: passo 1, imagem 3 %32
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Front Panel Replacement: passo 2, imagem 1 %32
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Front Panel Replacement: passo 3, imagem 1 %32
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Front Panel Replacement, Front Panel: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-W170 Front Panel Replacement, Front Panel: passo 4, imagem 2 %32 Sony Cyber-Shot DSC-W170 Front Panel Replacement, Front Panel: passo 4, imagem 3 %32
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Front Panel Replacement: passo 5, imagem 1 %32
    • Gently open the front panel and remove it from the rest of the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 77
