Ir para o conteúdo principal
Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 1 %32
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 2, imagem 1 %32 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 3, imagem 1 %32 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 3, imagem 2 %32 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 5, imagem 1 %32
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 6, imagem 1 %32 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 6, imagem 2 %32
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 9, imagem 1 %32 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 9, imagem 2 %32
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 10, imagem 1 %32 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 10, imagem 2 %32
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 11, imagem 1 %32
Conclusão
Uma outra pessoa concluiu este guia.
Dana Sanchez
Membro desde: 10/21/14
51 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-5, Leahy Fall 2014 Membro de USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 46
Duração total: 1,721
