Ir para o conteúdo principal
Sony Cyber-Shot DSC-TX9 Lens Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: passo 1, imagem 2 %32 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Lens Replacement: passo 2, imagem 1 %32 Sony Cyber-Shot DSC-TX9 Lens Replacement: passo 2, imagem 2 %32
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Lens Replacement: passo 3, imagem 1 %32
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Lens Replacement: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-TX9 Lens Replacement: passo 4, imagem 2 %32
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Recognizing & Disconnecting Cable Connectors) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Lens Replacement, Lens: passo 5, imagem 1 %32
    • Using the tweezers carefully remove the broken/damaged lens with its attached circuit board
Conclusão
robert.oliver6
Membro desde: 03/23/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 380
