Introdução
This guide will demonstrate how to replace the Memory Card Reader. This will fix the "Unable to read memory card" Error.
O que você precisa
Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
Using a Phillips head screw driver, remove the two screws for the metal plate on the bottom.
Detach the smaller ribbon cables by sliding them out.
Detach the large ribbon cable by flipping the small black holder in an upright position and then sliding the cable out carefully.
