Ir para o conteúdo principal
Sony Cyber-Shot DSC-TX30 Outer Shell Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement, Battery: passo 1, imagem 2 %32
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 2, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 2, imagem 2 %32
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 3, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 3, imagem 2 %32
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 4, imagem 1 %32
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement, Outer Shell: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 7, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 7, imagem 2 %32
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 8, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 9, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 10, imagem 1 %32
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 11, imagem 1 %32
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 12, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 12, imagem 2 %32
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 13, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: passo 13, imagem 2 %32
    • Remove the front casing of the device.
Conclusão
Um comentário
hello sir do you have sony tx30 case ? because my battery lock hole loose … please thanks
John Anthony Geronez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 801
