Ir para o conteúdo principal
Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: passo 1, imagem 2 %32
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 2, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 2, imagem 2 %32
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 3, imagem 1 %32 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 3, imagem 2 %32
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 4, imagem 1 %32
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 6, imagem 1 %32
    • Using your fingers, remove the battery/memory card door seal.
Conclusão
3 comentários
hi sir do you have battery lock for replacement ?
John Anthony Geronez - Responder
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - Responder
Where can I get the door catch - is it still available?
sid123 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Duração total: 1,540
