Ir para o conteúdo principal
Sony Cyber-Shot DSC-S90 Back Case Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: passo 1, imagem 2 %32
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Back Case Replacement: passo 2, imagem 1 %32
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: passo 3, imagem 1 %32 Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: passo 3, imagem 2 %32
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Back Case Replacement: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-S90 Back Case Replacement: passo 4, imagem 2 %32
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Back Case Replacement: passo 5, imagem 1 %32 Sony Cyber-Shot DSC-S90 Back Case Replacement: passo 5, imagem 2 %32
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Back Case Replacement: passo 6, imagem 1 %32
    • Pull apart the back case from the main body of the camera.
Conclusão
Equipe
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G5, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G5
Membros da 3
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 191
