Ir para o conteúdo principal
Sony Cyber-Shot DSC-H200 Battery Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-H200 Battery Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-Shot DSC-H200 Battery Replacement, Battery: passo 1, imagem 2 %32 Sony Cyber-Shot DSC-H200 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Push the SD Door switch toward OPEN with right thumb.
    • While you do this simultaneously press the SD Door switch away from the center of the camera with your left thumb (the SD door will open).
    Hello, good job
    I want to know how to tear off the battery cover.
    I need help please !!
    Donnovan Smith - Responder
    Hello, good job
    I need help Please !!
  2. Sony Cyber-Shot DSC-H200 Battery Replacement: passo 2, imagem 1 %32
    • Take the four AA batteries out of the battery compartment.
Conclusão
3 outras pessoas executaram este guia.
1Comentário do guia
Are there specific (brand) batteries that work with this camera? I
ve used panasonic bqcc55 rechargables but no success
alesiawhite_2 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 91
Ao todo: 9,270
