Ir para o conteúdo principal
Sony Cyber-Shot DSC-H1 Lens Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: passo 1, imagem 1 %32
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 2, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 2, imagem 2 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 2, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 3, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 3, imagem 2 %32
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: passo 4, imagem 1 %32
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 5, imagem 1 %32
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: passo 6, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: passo 6, imagem 2 %32
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 7, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 7, imagem 2 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 7, imagem 3 %32
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 8, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 8, imagem 2 %32
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 9, imagem 1 %32
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 10, imagem 1 %32
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 11, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 11, imagem 2 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 11, imagem 3 %32
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: passo 12, imagem 1 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 12, imagem 2 %32 Sony Cyber-Shot DSC-H1 Lens Replacement: passo 12, imagem 3 %32
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
Conclusão
3 outras pessoas executaram este guia.
Charlie Pugeda
Membro desde: 03/19/18
505 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S5-G4, Williams Spring 2018 Membro de Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Duração total: 1,441
