Introdução
If the camera lens is unrepairable, you may just need to replace it with a brand new one. This is how you take it apart before you insert a new one.
Peças
Não são necessárias peças.
  1. Power down the camera and remove the batteries.
    • Power down the camera and remove the batteries.
  2. Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
    • Unscrew and remove the gray backing behind the LCD screen.
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
    • Remove the motherboard and battery pack unit.
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Charlie Pugeda
469 reputação
3 Guides authored
Equipe
Baylor, Team S5-G4, Williams Spring 2018 Membro de Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Todo: 187
