Ir para o conteúdo principal
Sony Cyber-Shot DSC-H1 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, Back Panel: passo 1, imagem 1 %32
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 2, imagem 2 %32 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 2, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 5, imagem 1 %32
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
Conclusão
Trystan Jasperson
Membro desde: 03/17/18
231 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S5-G4, Williams Spring 2018 Membro de Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 550
