Ir para o conteúdo principal
Sony Clie PEG-SL10 Motherboard Replacement
O que você precisa
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: passo 3, imagem 1 %32
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: passo 4, imagem 1 %32
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: passo 5, imagem 1 %32
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: passo 6, imagem 1 %32
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: passo 7, imagem 1 %32
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: passo 8, imagem 1 %32
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: passo 9, imagem 1 %32
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: passo 10, imagem 1 %32
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: passo 11, imagem 1 %32
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Conclusão
Emily
Membro desde: 10/18/11
3 Reputação
Autoria de 3 guias
Equipe
James Madison, Team 1-4, Allen Fall 2011 Membro de James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
Membros da 3
Autoria de 4 guias
Um comentário
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 31
Duração total: 1,328
