Introdução
Installing a new speaker fairly simple as it only involves opening the device casing and then removing the broken speaker.
O que você precisa
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
Remove the tape holding speaker wire by peeling it away.
Quase terminado!
Conclusão
