Introdução
If the screen is damaged, then you may need to replace it. This guide will walk you through the process of replacing your screen with a new one.
O que você precisa
Remove the two 1.5mm screws (one on the right and one on the left side) on the screen portion of the device with a Phillips #00 screwdriver.
Uma outra pessoa concluiu este guia.
